Initial comments on the Samsumg T3093WH slim fit crt TV.
It fit nicely in the space the old 27 Hitachi occupied.
There is a slight electronic burn-in odor. I expect this to dissappear as the TV is used.
What will take some getting used to is the quick tempo string of notes that plays as the TV is turned on/off. It takes about 5 seconds from pressing the power button to an image appearing on the screen.
The remote is quite nice. Intuitive with relatively sized buttons. A yellow button that lights the 5 most common use buttons(2 volumn, channel up/down and On/Off).
I was unable to do the vertical line test vs shadow mask in the store. Attached is a macro of the screen. I think it is SD via cable of the preview channel.
More to follow as I use this set. The set is supposably Firmware upgradeable via USB port on back.
