Once again I need some advice-I would like to download movies and then burn them so that I can play them on my dvd player and watch on our TV-I have downloaded a couple of movies useing the website LimeWire-But the problem is that they will only play on the computer,when I put the Maxell DVD- 4.7gb- disc into my Panasonic dvd player a notice comes up saying that I can`t play that disk on that machine-I have recorded the movie useing avi because just about all the movies on LimeWire have that formatI have been doing a lot of research trying to find the best site to use but to be totally honest I do not know a good one from a bad one-It seems like most of the sites want to sell you different software to download,burn,etc.-I do not have a problem buying what ever is needed to download etc.I just do not want to be the person that is getting burned-
I am useing windows xp with a VALO pc and like I said I am trying to play on a Panasonic DVD player and useing drag and drop to burn the discs.
Any advice that you can offer me would really be appreciated.
harleytio
You have to convert the AVI to MPEG and author,look to left "How To Convert" and "Author".
Thank You for your reply Moviegeek-But where do i go to find the place to complete the task that you so kindly suggested?
harleytio -
If your DVD player doesn't play AVI type files such as Divx, then as MOVIEGEEK suggests, you will need to convert them to DVD compliant video and burn to disc. For simple, try ConvertXToDVD. There is also a older freeware version, DivxToDVD still available and a few other 'All-in-one' converters in our 'Tools' section to the left. <<<<<<
And harleytio, in the future, please use a subject title that is more descriptive of your subject to allow others to find it with a forum search. I will change yours this time.
Moderator redwudz
And welcome to our forums. -
redwudz:
I will try harder in the future to comply with a better description of my need of help in the subject title-Sometimes when a person is just starting out and asking for help it is not easy to put a persons thoughts into printed words-Hopefully when I gain more experience,I will be better at makeing everyone happier.
harleytio
TV Settop box to DVD
By Quickshot in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2010, 08:00 -
How to convert dvd movies to DX50
By mbworldz in forum Video ConversionReplies: 8Last Post: 18th Jan 2010, 12:26 -
Convert movies from my ipod touch to PS3 and DVD Player
By d_unbeliever in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 06:05 -
Convert movies to DVD
By neonblade in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2007, 01:32 -
Making a compliant DVD for settop players?
By hopealaska in forum Video ConversionReplies: 5Last Post: 6th May 2007, 18:08
