Hello to all of you
After 1 week of continuous searching I have decided to post my problem here. What I have is two avi files from a football game that I am trying to append in VirtualDub/VirtualDubMod
I have managed to do this before several times until now.
The error I keep getting is:
Cannot append. The video streams have different data formats. I will also post a JPEG with the file information of each file. I believe it has something to do with the audio codec...but I couldn't find any workaround.
Thank you all for reading my message or for eventually trying to help me.
Mihnea
Try AVIDemux. Open the first file. If the audio is VBR MP3, AVIDemux will ask if you want to create a timemap. Say Yes, then click on File->Append and select the second file. Again, create a timemap if asked. Make sure both video and audio are set to copy mode, and save your new, combined avi file.
Read my blog here.
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
Merging avi files with subtitle and aac soundtrack
By kurian in forum Video ConversionReplies: 5Last Post: 31st Jan 2011, 03:52 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 15:20 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 10:50 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
