i have avi files that i want to burn to dvd, but i would also like to include subtitles on the dvd
be it from .srt or .sub files
what is the best software to use for this
sorry if i have missed the answer somewhere else
thanks
	.srt files are simple text files, so quite a few programs will accept them.
 ConvertXtoDVD will find the .srt file automatically if it has the same name and is in the same folder as the avi file.
 I believe the latest tmpgenc DVD author will as well, but you may have to encode your video and audio elsewhere, then come back here to author.
 DLP will also use .srt files.
 I don't work with .sub files, so I'm not sure how widely or easily they are supported.Read my blog here.
	thanks, i am checking out the sources you told me about as we speak
  ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitlesBy eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22
  DVD software player- raise subtitles to top of scrn/ simultaneous subtitlesBy jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30
  Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23
  Burning .mkv file with .ass subtitles to DVD WITH the subtitlesBy isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
  Help with converting DVB subtitles to idx/vob subtitlesBy Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
