i have *.avi file:
Video:
Audio:
i wanted to convert it to Xvid, so i used AutoGK for it,
the result was audio out of sync.
so i tryed VDubMOD with two passes conversion and this is what i'v got after 2 minutes of process:
after clickin "Exit Program", i got this:
what did i do wrong?
what is the problem?
how can i convert it to Xvid using VDubMOD or AutoGK without run into this issues?
Thanks in advance!
				Results 1 to 9 of 9
	celtic_druid,
 thanks for the reply man!
 how can i change the FourCC (what ever it is) to Xvid?
	Select your file, type "xvid" into the top box, "XVID" into the bottom box, Apply.Originally Posted by jagabo
	Install the Xvid codec? Did you follow my instructions exactly? The fourcc can be case sensitive. Be sure the top box is all lower case xvid and the bottom box is all upper case XVID.
	jagabo,
 OK thanks - i got it!
 i've picked Div4 (or something like that...) by mistake...
 sorry for the bother, and thanks again!
  3ivx questionBy Gary Esposito in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2009, 18:04
  3ivx Batch Conversion Available? Possible Script?By fitch.j in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2009, 06:24
  xvid target size problemsBy Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 16:11
  Problems with XViDBy trolldown in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 17:32
  Xvid playback problemsBy drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 22:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
