Hi. TMPGEnc is not working for me. It's giving me a Buffer overrun error when I load a certain avi file into it. It works fine with other avi's just not this one. I tried TMPGEnc Plus but I'm not having good results with it(the quality). So what else is there that converts avi to mpg without changing the aspect ratio and not reducing the quality too horribly? Thanks.
Results 1 to 11 of 11
I would start by looking at the offending avi file to see if there is something you can change to make it work. It could be something simple like changing the audio format before you feed it to tmpgenc. G-Spot can tell you what you have. If it is VBR MP3 audio then it might be worth replacing this with an uncompressed version instead, then encoding.
ConvertXtoDVD is a pretty good choice for this type of work, but it's not free.
DVD Flick seems to have it's fans for a free solution.Read my blog here.
I tried gspot and I have VBR MPEG-1 Layer 3 audio. I have convertxtodvd. Can this program convert to mpg too? I tried using DVD Flick with a tutorial on this site but I couldn't get it working the way I needed it to get working.
My goal is just to convert this avi to mpg format(without changing the aspect ratio and the quality not getting messed up too much). -
What is the ultimate goal ? i.e. does the mpeg have to be DVD Compliant ?
If it does, then you can use VOB2MPG to extract the mpg file from ConvertXtoDVD's output.
Simpler is to change the VBR MP3 audio to uncompressed PCM, then try tmpgenc again. This post : https://forum.videohelp.com/viewtopic.php?t=309224 tells you how to do it. It is in the context of audio sync issues, but VBR MP3 audio can do odd things to some encoders anyway.Read my blog here.
The ultimate goal is for the mpg to be able to load into TMPGEnc Xpress so I can author a DVD in that program.
I tried installing .net framework 2 but I'm having trouble figuring out which download I need. x86, x64, or IA64? I have windows xp professional edition but not sure what kind of bit processor I have. -
Right-click on My Computer and select properties. If you are running the 64 bit version of XP it will tell you here. However, if you don't know, chances are you aren't, so the x86 version is all you need.
Why do you need an mpg to load in tmpgenc express ? Doesn't it take avi files and convert them ?Read my blog here.
Originally Posted by guns1inger
sorry I didn't check that thread I thought it was only a vista problem. So you were having a buffer overrun error too? Where do you go... I can't seem to find the environmental option in the options or the direct show.
It's giving me this error for another episode too... grr. -
sorry I took so long lol. I have a tendency to put things off for a while and I forget about them. I tried what you told me and it works. So thank you for the advice gunslinger and sorry for taking so long to reply
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 00:21 -
Mpg Audio not working
By snpri3 in forum AudioReplies: 9Last Post: 7th Mar 2008, 11:31 -
Need a H-Quality AVI to MPG BATCH converter - As good as Sony Vegas
By Ratman in forum Video ConversionReplies: 3Last Post: 18th Oct 2007, 12:42 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
