Hello everyone,
I have an H.264 mp4 file that I've been trying to convert to an xvid avi file. I usually use an avisynth script like, DirectShowSource("filename.mp4"), to load the mp4 file in to virtualdubmod. From there I just convert it using the xvid codec. However, when I tried to use that script on this specific file vdubmod gives me the error "no video stream found".
The file plays fine using media player classic and vlc; however, only the audio plays in quicktime. When I used Gspot to determine if I had the correct codecs for the file it said my codec status is undertmined. I have ffdshow installed and the libavcodec is being used to decode H.264 files.
The file only consists of a H.264 mpeg4 video track and an AAC audio track. I've tried various programs to convert or demux the mp4 to no avail. Any help provided would be greatly appreciated.
I previously tried using YAMB but the resulting demuxed files were always corrupted. I think I found a solution. I tried using Dr. Divx and for some reason that program worked. Even though it may not be the best solution I think I'll convert the original file to a large divx file and then compress that using xvid. Thanks for your help Soopafresh.Originally Posted by Soopafresh
Converting H.264, MP4, M2TS issues
By evilronin in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Jul 2011, 22:03 -
Error when converting to MOV, MP4, h.264
By marcoscabral in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2009, 14:00 -
converting MOD to AVI to MP4 using avisynth, x264, mp4box & ffmpeg
By Wakewatcher in forum Video ConversionReplies: 3Last Post: 27th Dec 2008, 17:58 -
Help Converting XVid AVI to x264 with VDubMOD or other?
By incrediblej in forum Video ConversionReplies: 5Last Post: 1st Jan 2008, 15:13 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
