and ive seen other people with this prob, but no answers. oddly the first 21 videos i converted to flv work fine, but then i started not working.
i tried converting a couple different formats to flv,
but it either fails, or finishes the encode in about a second, and outputs a blank file (Zero kb).
so heres the error message:
avi to
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
Sat May 5 19:05:32 PDT 2007
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, dv, from '/Volumes/LaCie Disk/Cades/Escuela/conquer/pelota dv stream.dv':
Duration: 00:07:57.5, start: 0.000000, bitrate: 28771 kb/s
Stream #0.0, 29.97 fps(r): Video: dvvideo, yuv411p, 720x480, 28771 kb/s
Stream #0.1: Audio: pcm_s16le, 32000 Hz, stereo, 1024 kb/s
bench: utime=0.012s
Output #0, flv, to '/Volumes/LaCie Disk/Cades/Escuela/conquer/pelota dv stream.dv.ff.flv':
Stream #0.0, 23.98 fps(c): Video: flv, yuv420p, 640x272, q=2-15, 940 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[mp3 @ 0x45a630]flv doesnt support that sample rate, choose from (44100, 22050, 11025)
Could not write header for output file #0 (incorrect codec parameters ?)
Encoding completed on Sat May 5 19:05:32 PDT 2007
and another
Seems that stream 0 comes from film source: 30000.00 (30000/1) -> 30.00 (30/1)
Input #0, avi, from '/Volumes/LaCie Disk/Cades/Escuela/conquer/pelota right size.divx':
Duration: 00:07:57.9, start: 0.000000, bitrate: 1139 kb/s
Stream #0.0, 30.00 fps(r): Video: mpeg4, yuv420p, 640x360
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 128 kb/s
Sat May 5 19:18:22 PDT 2007
Output #0, flv, to '/Volumes/LaCie Disk/Cades/Escuela/conquer/pelota right size.divx.ff.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 720x480, q=2-15, pass 1, 940 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
bench: utime=0.023s
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 720x480, q=2-15, pass 2, 940 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
i tried a bunch of different settings, but not luck
thanks
cade
Results 1 to 16 of 16
I saw a Yeee Haww! there, but I cannot say the same. I'm getting 0kb files no matter what I do.
I cannot create FLV files whatsoever? Why this problem. I followed all installation instructions to no avail.
Can you help? See the picture attached.
Other things to note:
> Cannot preview.
Thanks.
Still no joy. OK here's the log
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Fri Sep 21 16:36:38 CEST 2007
#0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/ginablewitt/Desktop/untitled folder 10/extractsolo.mov':
Duration: 00:01:20.6, start: 0.000000, bitrate: 221 kb/s
Stream #0.0(eng): Audio: aac, 32000 Hz, stereo
Stream #0.1(eng), 11.99 fps(r): Video: h264, yuv420p, 320x240
Output #0, flv, to '/Users/ginablewitt/Desktop/untitled folder 10/extractsolo.mov.ff.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
bench: utime=6.661s
video:977kB audio:551kB global headers:0kB muxing overhead 81.474086%
Encoding completed on Fri Sep 21 16:36:45 CEST 2007
Can anybody help?
I don't know if this is your problem, but your pathname contains spaces. Many modules used by ffmpegx don't handle those gracefully. Try removing spaces, etc. from the pathname and try again. Observing this rule avoids many problems of exactly the type you're having ("I followed all the instructions, but I get 0kB output").
Hope this fixes it. If not, someone smart will post and tell you what to do.
[No one smart has posted yet, so I'm posting instead. Too bad for you!]
Presumably you've chosen the "decode with QT" option. Have you tried playing the source file with QT? If so, are you able to hear sound there? If not, then the problem lies there. Ffmpegx won't be able encode into something if it can't decode the source properly, so that problem has to be addressed first.
Another person unable to convert to Flash. Here's my '(i)' output:
Fri Oct 26 11:29:48 EDT 2007
Input #0, mpeg, from '/Users/rae/Desktop/MOV06658.MPG':
Duration: 00:00:56.6, start: 0.070000, bitrate: 10477 kb/s
Stream #0.0[0x1c0]: Audio: mp2, 32000 Hz, mono, 64 kb/s
Stream #0.1[0x1e0], 30.00 fps(r): Video: mpeg1video, yuv420p, 640x480, 104857 kb/s
Codec type mismatch for mapping #0.0 -> #0.0
I tried matching the audio in the output (i.e. no transcoding required), but I think the "#0.0" means it's a video issue, not an audio issue.
This mpeg was recorded with my Sony CyberShot. I've tried saving as a self-contained movie in QuickTime, and "use QT to decode", which gets me the below, even though it plays fine in QuickTime.
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/rae/Desktop/MOV06658.mov':
Duration: N/A, bitrate: N/A
No audio or video streams available
Fri Oct 26 11:32:33 EDT 2007
Any help appreciated.
Also, any thoughts on going open source?
Reid
Your source file has the audio stream (#0.0) mapped before the video stream (#0.1). This is reverse from what the ffmpeg engine expects. You may fix this "Codec type mismatch for mapping"-error by indicating that the streams are reversed. To do so, check the "Invert mapping" checkbox in the audio tab.Originally Posted by rae
Can I Convert Flash files?
By humphz in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2010, 00:40 -
how to convert avi to flash video 4!!!
By dsl123 in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 10:09 -
Can't convert to flash format
By jweb in forum ffmpegX general discussionReplies: 2Last Post: 4th Apr 2009, 03:01
