TMPGenc 2.5 did work in XP but in vista the image dv avi is black. The same dv avi file made in Premere Pro, can be viewed in this vista pc with other viewers such as window media player. I checked the codec in gspot and it is dvsd DVC/DV Video. Why can't this ap read the dv avi file and how can I get it to work?
I haven't had any problems opening DV with TMPGEnc 2.5 in my Vista computer. But I do have the Panasonic DV codec installed.
If you mean with TMPGEnc, you might look here for common problems and solutions: https://www.videohelp.com/tmpgenc.htm#problems
I have also frameserved from VD Mod to TMPGEnc and that seems to help it accept a file. I don't think Vista is the problem, it's more likely your file or some missing codecs or you need to set the direct show reader to a higher priority. -
I've only ran into that a few times. I suspect it may relate to a codec that 'takes' over and sets itself up higher in priority than the one you are needing. But if it works now, great.
SVC2DVD quit working on VISTA SP2
By artar in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 25th Aug 2009, 18:01 -
SVC2DVD not working on Vista
By davezim in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 20th Aug 2009, 08:02 -
AviSynth is not working on Vista
By hzgg2 in forum EditingReplies: 1Last Post: 10th May 2008, 16:26 -
Games not working on vista?
By silith in forum ComputerReplies: 8Last Post: 29th Apr 2008, 19:27 -
Vista DVD Maker (isn't working)
By naomi c in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 05:30
