    Jan 2006
    Sorry if this is in the wrong forum, but I'm having trouble finding this specific topic.
    I have a VIDEO_TS folder on my hard drive (3.6 GB), and I want to split it up into 700 MB chunks with an mds file. Can ImgBurn do this, and if so, could someone point me to a step-by-step guide? ImgBurn itself isn't very clear on the subject. Thanks.
    Apr 2004
    Miskatonic U
    I don't believe imgburn will do this for you. It will create a single ISO with MDS file, which you can then split up yourself using HJSplit or even WinRAR.
    Read my blog here.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What is your final use? Storage of the dvd image or playable cd size files?
    Google is your Friend
