hi i was hoping to make a h264 and acc file into a hd-dvd both are located in a mkv file...is there anyway to do this
Have you tested any all-in-one hd-dvd tools like Ulead DVD Moviefactory? But I guess that they don't support any mkv...and maybe just mpeg2 hd.
You could try demultiplex out the video and audio with mkvextractgui. Convert the audio to ac3 with DAudioK. Then play around with the current authoring tools and see what can import h264, if it's hddvd compliant then, https://www.videohelp.com/tools/sections/authoring-bd-hd-dvd
Or just build/buy an HTPC that can play everything. -
everything seems to lock up if i could get x264 and ac3 into another format than i would be good
Difference between ac3 and acc
By nicknack74 in forum AudioReplies: 1Last Post: 26th Jul 2011, 05:48 -
acc to wav
By pradeesh in forum AudioReplies: 8Last Post: 15th Mar 2011, 23:33 -
Tool or command line to batch remux x264 acc .mp4 in .flv
By Gargalash in forum Video ConversionReplies: 6Last Post: 25th Aug 2010, 08:29 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
