I have 2 different dates of live music with complete VOB, IFO and BUPs for each but I want to put them onto 1 disc. They dont have menus or chapter points. Id like to make a top menu to list both dates, and link to submenus for each date with chapter points for all the different songs. I searched here and found this guide for combining the file sets, but couldnt create the submenus like I want with TMPGEnc. Is what I want even possible? if so what software will allow me to do it? Thanks for any help with this.
TMPGEnc DVD Author
Click Source Setup and choose Add DVD Video for each VOB.
Click Create Menu and create a menu
Click Output and choose a folder to create your TS folder
If you get a warning that file is too big, shrink file with DVD Shrink and burn with software of choice. DVD Decrypter, Nero, TDA etc... -
If you want to do it for free, use VOB2MPG to extract the video/audio out of the VOB structures, then GUIForDVDAuthor to author a new disc, and imgburn to burn the results.
Read my blog here.
Thanks for the replys you two. I was working with the trial version of TMPGEnc DVD Author and couldnt get the menu to work out like I wanted, maybe because it was the trial? I am going to give guns1inger's suggestion a shot.
Last night I found out my friend has Sony Vegas and DVD architect on his work laptop and he said one of those might be able to do what I need. Anyone know if this is correct? -
What version number are those, and are they the "Studio" or "Full" versionsOriginally Posted by pheldd
Regards,
George
Question about which editor I should use for a specific task.
By DoctorDyna in forum EditingReplies: 6Last Post: 1st Feb 2012, 11:34 -
Best software for my streaming task?
By Chala in forum Video Streaming DownloadingReplies: 0Last Post: 12th Sep 2010, 21:04 -
iexplore/task manager problem
By mysts in forum ComputerReplies: 2Last Post: 6th Jul 2009, 23:24 -
Task Scheduling
By Squid_uk in forum ComputerReplies: 1Last Post: 16th Apr 2008, 13:33 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 08:51
