i want to buy a dvd burner and cd burner and reader and i was wondering what you guys had to recommend, i want something that is not too expensive probably around 40 dollars.
thanx
Results 1 to 9 of 9
PIONEER 112D would be a good choice at the moment. It's riplocked so to increase read speed you'll need to use MEDIA CODE SPEED EDIT program. Or you can buy a LITEON 18x or 20x speed dvd burner which is fast at ripping discs.
PIONEER 112D
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129007
LITEON 18x
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106042
LITEON 20x
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106050 -
They are all about equal, it just boils down to price and brand preference.
Google is your Friend -
Others recommend a Lite-On - agreed.Originally Posted by econtrerasguzman
Also - look around for a Benq 1650 or 1655.
If you can pick one up cheap, they are great drives also.
Maybe EBay? -
Pioneer
I agree with you 100%.I think the media brand is more important than the burner these daysOriginally Posted by Krispy Kritter
I agree with the media being more important. I have two of the 20X lite ons and i never burn at speeds more then 6X for videos. if you burn at these 16 to 20x you will have more playback problems on a set top dvd player. So what is the real sense of these speeds. I think they are just trying to impress each other by seeing who can make the fastest burner.
Some brands are more media tolerant than others - even today.
If you check the media reports on this site, you can see whether the brands of media you are likely to use are likely to be compatible with the drive.
Of course you can also follow the advice of many posters and limit your media choices to TY and Verbatim. In which case almost every drive will work.
I buy whats on sale at local retailers and burn at full speed. No coasters, no freezes. At this point I have burned thousands of DVDs and a few hundred CDs. -
I use Taiyo Yuden and verbatim and i also use sony dvd-r's that are in the 100 pack. these are made in taiwan and i have had no issues with these. The sony's in the 50 pack are made in malaysia and i have had problems with them. A lot of write fails. I use the Sony's 100 packs a lot because they are frequently on sale at best buy and staples. I have burned thousands of video dvd with these sony's with no problems.
card reader
By alintatoc in forum ComputerReplies: 5Last Post: 14th Nov 2009, 03:28 -
DVD writer/reader...unable to read DVDs
By maass in forum DVD & Blu-ray WritersReplies: 7Last Post: 9th Apr 2009, 12:08 -
NEC TV/ DVD reader model NLT-26HDDV3
By zambia_cr in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 13:37 -
dvdfab platinum can't find any reader/burner on my computer...
By kulmagen in forum DVD RippingReplies: 0Last Post: 21st Feb 2008, 10:34 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
