What do I do to convert a wmv file to avi, while achieving excellent quality. I am not sure which program to use. What do you guys recommend?
	What format of AVI? There are probably a hundred of them.  AVI is just a container name. If you want to descirbe a format, state the codec used. AVI is just a container name. If you want to descirbe a format, state the codec used.
 But try SUPER first. Not the best, but easy to use. Even WMV has quite a few formats. You may have problems with some of the newer formats or DRM if you are trying to convert to a AVI type format.
 A few others: alltoavi, or depending on the WMV format, Virtualdub 1.3C or even Window Movie Maker and output in DV format.
	Some of the later VirtualDubMod (or is it mpeg2 - I always forget!) can load wmv, and easily then convert to AVI, like DV or DivX or XviD to name a few AVI codec.
 /Mats
  AVI or WMV?By NyTeHaWk in forum Video ConversionReplies: 3Last Post: 3rd Jan 2011, 18:34
  .wmv to .aviBy cyberlion in forum Video ConversionReplies: 7Last Post: 11th Oct 2010, 16:37
  WMV-to-AVI please?By snadge in forum Video ConversionReplies: 3Last Post: 28th Sep 2009, 14:38
  Avi to WMVBy ichigo15 in forum Video ConversionReplies: 5Last Post: 20th Aug 2008, 18:18
  .WMV to .AVIBy korki696 in forum ffmpegX general discussionReplies: 2Last Post: 15th Jun 2008, 22:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
