    May 2007
    Whats the easiest way to create 5 or 10 minute chapters using CCE?
    Jan 2007
    AFAIK CCE doesn't do that
    chapters are created in the authoring stage, NOT the encoding stage
    for me anyway the chapters are created at the time interval I want when i author the DVD in GFD,
    convertX ( 1 click ) will create chapters, but the chapters are created in the authoring stage , after the video is transcoded
    encode, edit, author each step does different things
    Aug 2004
    CCE 2.70 can create chapters.
    @hipatuga1
    Other than manually putting them in there is no easy way. Or another option is to load up a pre-determined celltimes.txt file of the chapters.
    Apr 2004
    Miskatonic U
    Don't confuse chapters with titles. Chapters are markers set during authoring. Some encoders (CCE is one of them) can be told where your chapter points will be so that I frames are encoded in the right places for later authoring. However you still have to tell your authoring tool where these chapters points are.
    Read my blog here.
