I used the WinAVIVideoConverter program to change AVI files to DVD I used my Samsung external burner to burn the files to disc when I put them in my Goldstar VM681M DVD player it does not read the disc I have played other burned discs without trouble on my DVD player is there another format I need to put the video files in to play them?
Thanks,
G
Try imgburn to burn the dvd files. If that don't work then ditch winavi as your all-in-one converter and use convertxtodvd. Winavi doesn't have a good rep as an all-in-one.
I use winavi all the time without problem. Which burning software did you use and which media? Have you tried the internal burner in winavi ? I have used it in winavi8 and the previous version and the dvd's play ok in 2 dvdplayers in our house. I also use Gear Pro which also works.
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:59 -
why will some avi files play in my dvd player while others will not?
By panman36 in forum Newbie / General discussionsReplies: 6Last Post: 8th Nov 2010, 10:58 -
various movie files converted to play on dvd player
By SPORTSGUY88 in forum MacReplies: 4Last Post: 3rd Aug 2010, 10:25 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 19:38 -
DVD player to play .avi files
By micallen in forum DVD & Blu-ray PlayersReplies: 11Last Post: 23rd Nov 2007, 14:14
