I recently sent some DVDs off for duplication and the duplicator informed me that there was a problem with one of them. It turns out that the problem was that I had taken an .img file and used Power ISO to add a folder with a pdf file in it. The reason the other DVDs did not have a problem was because I added the ROM content at the time the .img file was built with Adobe Encore DVD.
So my issue now is that I have to add ROM content to 15 older DVDs of which I only have .img files for (I also have the DVDs themselves of course)
I'm guessing that when I re-saved the .img file with PowerISO, it somehow made it incompatible with the duplicator's DVD player because when I rebuilt the same DVD with the PDF file included in the build process of the authoring software, it worked fine.
My question is if there is a specific software I can use to add this ROM content to these image files, but not corrupt any file structure or anything else so that it won't cause any compatibility issues?'
Thanks!
				Results 1 to 12 of 12
	No, you have to extract the content of the image file (mount it with daemon tools and copy its content to your HDD), add the "ROM content", then create a new image.
 /Mats
	With this software, it looks like I can just open the ISO file and add the content folder and save the ISO (without ever having to actually extract and recreate the ISO) Has anyone used this?
 http://www.magiciso.com/index.htm
	No, as it's a commercial product that doesn't do anything that can't be done with freeware (even if the MagicIso way is a bit more elegant), I've not used it.
 Extracting and rebuilding the ISO is so quick and simple, I see no real reason for using MagicIso
 /Mats
	power iso didn't do the job; the DVD was kicked back for incompatibility...
	Hence my question.
 If PowerISO couldn't push a folder into an ISO successfully, why trust a product called MagicISO (a name that puts me off straight away) to do it ?
 I'd have to agree with Mats on this one - extract the ISO back your HDD, add the folder and contents, then build a fresh ISO.Read my blog here.
	"Never trust an application with 'Easy', 'Eazy', 'EZ', 'Express' or 'Magic' in its name"
 Of course there are exceptions to this rule, but they are few.
 Also: Commercial products are made to make money. Freeware is made to accomplish tasks.
 /Mats
	Most likely when you rebuilt the ISO image, the software did not place the files in their proper order for DVD-VIDEO. So make sure whatever you use is setup to build the ISO Image properly (after adding the dvd-rom content)...
 Regards,
 George
  3D dvd content - convert to Blu3D contentBy Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 08:52
  Exit to DVD-ROM content from a DVD menuBy SCDVD in forum Authoring (DVD)Replies: 7Last Post: 13th May 2009, 20:59
  Adding audio content to MKVBy txl in forum AudioReplies: 2Last Post: 30th Apr 2009, 16:49
  my instructions for accessing ROM content - good?By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 11th May 2008, 20:34
  Adding dynamic content to video stream.By Shawn Brant in forum Newbie / General discussionsReplies: 5Last Post: 22nd May 2007, 17:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
