    May 2007
    Title says it all hopefully this can be fixed soon, I get brought to a page of code.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Alt-Click ('Option-Click' if you're old-school) to force the browser to download to disk, instead of showing the binary content in a browser window.
    Or Control-Click to activate the contextual menu, then choose Save linked file.
    May 2007
    It just downloads a text file every time with random code
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Yes it does. And that's okay. The installer doesn't care about the filename extension of the binary.
    May 2007
    Hmm ok ty, tthough I dont get the option to save file todisk..ever
  6. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Even if you get the Safari browser window full of code, you can choose File>Save As and still get a valid file for the installer, as long as the file is complete (501480 bytes). [I expected that to fail on linebreaks and character encoding, but it worked.]
    The webbrowser Firefox behaves differently from Safari in this respect. If you would click the link in Firefox, you would get a dialog box stating "What should Firefox do with this file? One option: (•) Save to disk". Try that if you feel it's better.
    Hopefully we'll get a zipped copy for any future version. That should end this confusion.
