Hi all... I recently tried using WinFF to convert my .avi files with the sound still intact, however the converted files won't transfer over to my Gigabeat for some reason. WMP11 won't allow it saying that it can't convert between quality differences.
And Windows Media Converter just crashes on me every single time I start encoding? So Wha tdo I do in order to convert the .avi and keep the sound in sync?
*edit* Also, I've tried AutoMK and it converts and can transfer over, however the sound is like 3 seconds behind....
Results 1 to 14 of 14
better read up on just what your pmc requires first
From what I know the PMC requirements are almost exact to the Zune stuff... But EVERYTHING I've tried hasn't worked?!?!?! this is extremely frustrating. I've even played around with all the programs in this thread
http://www.mygigabeat.com/forum/messages.cfm?threadid=65B90ED6-3048-2906-EA541C00FEA3B741
And now I've gotten to close, but now the stupid player won't play it?!?! -
Take a video that will play in it , then disect it to find what the crucial ctriteria is -> resolution , codecs for video and audio , audio frequency , bitrates , or anything else I may have missed
with VideoInspector (or the other program whose name eludes me)
As I recall , a WMV is technically an avi (just a wrapper) but in reality it isnt , ie even with the right codecs , it has to be wrapped up properly by the encoder or it just makes some hybrid file of it which happily play a la pc but not in a program expecting 100% compliance to a standard .(I`ll be happily corrected on this , its not something I work with but was on the fringes of something I was working with). -
Turns out I need a converter with wmv3x that format... I guess autoMK has that, but when i tried it before the audio was out of sync?
So what does a video look like (detailwise) that will play in it ? and what differs from that to the ones you are making ?
the videos before I was able to play were from AutoMK and actually used the exact similar or same settings.... except then the audio was not in sync.... however now the videos won't actually play???? Is something wrong with the Gigabeat?
You`ll need to use VideoInspector to remove any problems associated with "similar" or "I think" - the results of `videos that work` and `videos that don`t` , will give you a baseline to work from .
help converting WMV to AVI
By user943 in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 10:39 -
Converting .WMV to .AVI - What should I use to do this?
By Hank Kinsley in forum Video ConversionReplies: 3Last Post: 16th Oct 2008, 04:54 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 04:15 -
Converting protected WMV to AVI ?
By rindless in forum Video ConversionReplies: 3Last Post: 10th Jul 2007, 13:31 -
CONVERTING FROM AVI TO WMV or RM
By sunsound in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 03:17
