Does anyone have a link for Amaray sized inserts?
A few Google searches threw up some brands, but upon taking a closer look, some of the reviews were from disatisfied customers unhappy with the fit of the sleeves
I need quality sleeves that wont result in creases, and do not have the crappy visable perforated edge that comes from tearing off each sheet
Also, I dont want to find myself pissing around with an artist knife trimming sheets down to size etc
Another idea I had, was to look for companies that sell DVD spec insert paper (like a pack of A4 printer paper, but in DVD cover size) rather than packs of DVD inserts, I havent been able to find any, a fact that surprises me somewhat
Oh and, a company in the UK would be best
I think I've tried about everything I could get my hands on. For the best quality, get yourself some high res inkjet paper or photo paper (8.5 x 14) and then cut them yourself. I use a paper cutter...the kind with the table and guide with a blade on the attached handle. None of the dvd insert paper matches the print quality you can get with quality paper...and it is usually much cheaper.
Google is your Friend
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 02:12 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:39 -
DVD plastic sleeves
By danielmak in forum MediaReplies: 2Last Post: 8th Mar 2010, 04:51 -
mailing envelope for standard amaray DVD cases?
By sdsumike619 in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2008, 01:07 -
any sleeves better than tyvek?
By spiffy in forum MediaReplies: 3Last Post: 20th Aug 2007, 13:15
