is it possible to use downloaded subtitles with dvds that i play on my computer? if so, how can i go about this?
If you use Media Player Classic, try opening the DVD, then on the file menu "Load subtitles" and select your subtitle file (probably an SRT).
However, you often have to resync subs. If so, try Subtitle Workshop. -
I've found KMPlayer to be the best and easiest for the purpose.
New versions of Nero Showtime display external subtitles with DVDs, as well.
PowerDVD also claims to support external subs.
Look here for details:
https://forum.videohelp.com/viewtopic.php?t=311996&highlight=
Downloaded a FLV, I've got only audio
By Puppybarf in forum Video Streaming DownloadingReplies: 7Last Post: 18th Jan 2011, 23:15 -
removing subtitles (foreign language) from a downloaded movie
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 22:40 -
Downloaded subtitles onto DVD
By turnip123 in forum SubtitleReplies: 6Last Post: 24th Dec 2008, 10:42 -
how can i add subtitles to downloaded dvd from internert?
By roboroach in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 17:30
