I have a dvd that I made from a vhs tape with a standalone dvd/vhs combo set top.
Now that i have the dvd I need to transfer it over to my pc and edit some of the clips out of it and maybe make chapters, titles, etc. I realize I can search google but I'd really like some first hand recommendations on software from someone that has done similar.
Thanks for any suggestions.
I second that.Originally Posted by guns1inger
One tip from personal experience: To cut bits out with a minimal need for re-encoding (i.e. around the cut area, rather than a large part of the footage), place the whole un-edited footage on the timeline and use the cut tool in the section to the right of the timeline.
Cut either side of the section to be removed and then delete the section.
I was doing cuts in the input window and finding that large parts of my footage was being re-encoded, meaning a reduction in quality.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks so much for the recommendation. It worked perfect. Now I just have to hope it will play in the DVD player of the person I am doing this for.
i had a problem with another program a while back that would play in some dvd players but not in others??? -
That's usually the result of incompatible media. You can check to the left under DVD players for compatibilityOriginally Posted by de8212
http://www.digitalfaq.com/media/ for more info . -
Well, ht eproblem was when I would burn tivo files to dvd. When I would do it with Sonic MyDVD it would no fast forward/rewind, etc. but it would play fine. Then I tried another program (using the same media) and itwouldn't even play.
Suggestions on video editing software
By Grunberg in forum EditingReplies: 11Last Post: 22nd Jun 2011, 19:39 -
Automated video editing software, suggestions.
By x2x3x2 in forum EditingReplies: 14Last Post: 18th Jun 2010, 01:37 -
Video Editing software suggestions for Panasonic HDC-SD9
By slickster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 10th Apr 2009, 11:09 -
Suggestions on editing files
By StarsFan4Life in forum Video ConversionReplies: 8Last Post: 29th Dec 2008, 18:30 -
Computer Suggestions For Editing?
By Ray & Paula in forum ComputerReplies: 9Last Post: 9th Apr 2008, 21:36
