    Apr 2007
    Australia
    Hi im just wondering if it is possible to merge 2 avi files that have different resolution, its the same movie but they got different resolution, so if it is possible im just wondering what i need to use to do it? thank you.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    They can't be merged, you need to convert them to match.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You will have to resize one of them to match the other. When you do this you also need to be careful that you don't screw the aspect ratio, as often this does not match either.
    Read my blog here.
