I searched all of the threads and cannot find a straight answer if it is possible to get DTS through a firmware upgrade on the 5960... Can anyone confirm if the 5982 has the option?
The player does not support DTS decoding. DTS decoding is hardware related, a firmware update will not "fix" it. The player should read DTS and forward it to your receiver, assuming your receiver has a DTS decoder.
Google is your Friend -
I think the original poster's point was that some budget players are just feature crippled versions of their upmarket equivalent and that installing third party firmware can often restore those missing features?
There has for example been a hack which re-enabled SACD playback on a budget player though only in two-channel mode. -
Which is understandable when a high price and budget priced player hit the market at the same time, however, the 5960 is a year older than the 5982. And hardware features typically aren't disabled just to make a budget player. They've already paid for the chipset (hardware) to provide the feature.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 22:28 -
Phillips 5982 no 5.1 over HDMI :(
By Fearnot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Mar 2008, 23:49 -
Philips 5982 and USB
By chits007 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2007, 09:43 -
philips 5982 with a better remote possible?
By wkk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Sep 2007, 23:32
