Results 1 to 18 of 18
    Jul 2006
    Hey ppl firstly i just want to say i wernt sure were to post this topic so i thought id would be ok here...
    The problem im having is when i burn a dvd on 2 cd with the cd being brand new no scratchs on it or anything, when i play it in my dvd player it either says cannot play disc is dirty or it will play but freeze quite alot i dont know why this happens, could it be that my dvd play needs to be cleaned inside? or would it be down to my disc or something???
    Can someone please help me out thank you
    Chana
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVD to CD?
    Jul 2006
    Nope dvd to dvd (4.7gb)
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Software used? Media used?
    He's a liar and a murderer, and I say that with all due respect.
  5. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Have you ever burned a DVD before and had it work in your player?
    Can you play the DVD on your PC?
    Could be you have an older Japanese player which does not like burned DVDs.
    Could be you have bad media.
    Could be you have a bad burner.
    Could be software.
    You need to provide detail before anyone can help you.
    Media, burner, software, player.
  6. Banned
    Freedonia
    Chana1 - You picked the right place to post. Your first post said that you burned "a dvd on 2 cd". Then you said "Nope dvd to dvd". Not much we can do when you deliberately give false information and expect us to just magically know what's correct and what isn't. If you REALLY want help, post in detail what you did as oldandintheway suggested and we might then have enough information to help you.
    Jul 2006
    I burn the .iso files i make out of the dvd (4.8gb) files using Nero Burning ROM, the cd's i burn them onto are:
    Datawrite Red 8x 4.7gb DVD-R (they have no scratchs obv)
    I dvd player i have is a sony 1 it says cd/dvd player dvp ns300 but when i typed it in google it comes up with a slightly different player mines in slimer and his a lil round knob on it (forward/rewind).
    Hope this helps, dont really know what the problem could be got a little feeling its the dvd disc but iv used these before and never had any problem and they have no mark or anything on them.
    Chana
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Datawrite get their discs from a wide range of manufacturers, mostof whom fall into the bottom tiers when it comes to quality. A quick scan of the media database (menu to your left) would indicate that Datawrite Red are at best a mixed bag. Use DVD Info Pro or similar to get the media ID for the discs, then look those up in the database and see what the feedback is. I suspect that crap discs is the root of your problem though. Add to this the fact that Sony players can be very touchy about the media they will use, and you have a good combination for problems.
    Read my blog here.
  9. Member buttzilla's Avatar
    Apr 2007
    Deep Space Nine
    The freezing can be caused by to fast burn speeds. try lowering them down a bit. I prefer 4 to 6X on dvd's and 16X on cd's and have very little freezing and breaking up problems. Use good media too. Sony verbatim taiyo yuden. Avoid cheap store brands like staples and dynex and others cheap media like memorex tdk .
  10. Member oldandinthe way's Avatar
    Mar 2006
    Older Sony players are notoriously picky about burned DVDs. They either won't recognize the disks or will freeze and pixilate during the movie.
    They often do not accept many of the "second" and "third" tier media makers. They prefer DVD-R when they are willing to read burned media. But some might also accept book-typed DVD+R.
    Higher priced media like TY or MCC (Verbatim) may work but also may not. SONY media are no longer first tier.
    You may get worse results with quality media if you burn too slowly.
    It may not be at all possible to read burned DVDs on your player.
    Not a very attractive situation.
    Jul 2006
    Ummm well im gessing the 100 dvd datawrite disc are waste then eyy waste of £12!! lolll which dvd discs would you recomend which play perfect and hopefully the film wont freeze on it, and cheap not looking for expensive 1's like 10 for £8 or something like that...
    Chana
  12. Member steveryan's Avatar
    Jan 2003
    Manchester
    Jan 2007
    you keep mixing words, one time you say DVD iso 4.7 gig
    in the next line you say you burned CD's
    you can't but 4 gigs on a CD
    also if the files are 4.7 you are going to have problems, you are burning to to the very edge of the disc and you are burning too fast
    I burn at 1/2 whatever the marked speed is, and for me anyway it works a lot better,
    also nero is a lousy encoder, and only a so-so burner compared to software like imgburn, nero's days as a tech leader are gone.
    I limit all my encodes to 4.2 MAX, for me anyway , it works out a lot better, for a variety of reasons
    if you use verbatim disc and have pro-sumer grade burners maybe you can burn to the edge and maybe you can burn at max marked speed
    for my equipment, taking the time burn it a slower means I don't make a coaster and have to do it all over again
    Jul 2001
    I think the OP is in the fairly early stages of dvd creation and propably doesn't have English as his first language.
    I fairly certain he's refereing to CDs as anything that round, fits in a tray on his computer and you can put it in another player when you're done burning things on it. Besides, they're using Nero...gotta feel for 'em.
    We have the same issue with people in the southren part of the US calling everything a 'coke'. Doesn't matter if you want a Pepsi, Mountain Dew or Dr. Pepper. Its all 'coke' to them.... Kinda like 'Band-Aid' being used for bandage all the time.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  15. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I need a Kleenex.
    Jul 2006
    Sorry about the words getting mixed, i type kind of quick and don't really read what i write some times lol. Sorry again.
    So if possible could you people by any chance post up some links were i can get some top quailty dvd discs 4.7gb 1's.
    Like "steveryan" has done and i am very greatful for it
    Chana
    Jul 2006
    Ne1 ?? answer the above ^^??
  18. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can't use google.co.uk, or go down to the local computer stores and browse ?
    Read nomorecoasters.com to find out what discs you should be looking for, then let your fingers do the browsing.
    Read my blog here.
