    May 2007
    Australia
    I have a WMV file that plays perfectly fine on the computer but after converting it to DVD using ConvertXtoDVD, I noticed that the audio goes out of sync about halfway into the movie (the audio is ahead of the video). Is it possible to fix this? Thank you in advance.
    Nov 2002
    Most WMV files are variable frame rate which will cause sync issues.
    I would try converting the WMV to either DVD compliant MPEG2 with TMPGEnc and author with a DVD authoring program (ConvertXtoDVD will also convert MPEG2 to DVD) or convert to AVI with TMPGEnc and run through ConvertXtoDVD.
