Hi there
When it comes to video editing I am kind of new. Just recently I downloaded a split dvdrip and came a cross a problem. I was using the latest version of VirtualDub to join the clips and I was unable to join the last video an error had come up "Cannot append segment : the video streams are of different sizes (592x320 vs. 512x384). Is it possible that I could change the video to 592x320 from 512x384 and how
Thanks in advance.
You can resize the frame but you'll have to reencode the video with the same codec and similar properties.
In short:
1) File -> Open Video File
2) Video -> Filters...
3) Add -> Resize
4) Set dimensions to the size you want. Use pulldown to select Lanczos3.
5) Video -> Compression...
6) Select desired codec and Configure...
7) File -> Save as AVI
Check out the all the guides via the menu item at the left of every page here. -
Of course those changes will also alter the aspect ratio, so you will get distorted images. It looks like your source material has been cropped differently, hence the odd sizings. You might better off simply keeping the original aspect ratio and resolution, and adding black borders to make the sizes match.
Read my blog here.
i have a video that has 2 audio streams..what does that mean?
By vincy in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 05:45 -
mp4 and multiple video streams
By hagai_sela in forum Software PlayingReplies: 24Last Post: 10th Nov 2011, 14:06 -
extraction of teletext from video streams
By ty7op5 in forum SubtitleReplies: 0Last Post: 9th Aug 2011, 15:29 -
Multiple Video Streams
By CthulhuSaves in forum EditingReplies: 7Last Post: 2nd Apr 2011, 19:28 -
Anyone know how to capture NBCOlympics.com video streams
By peggypwr1 in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2008, 01:01
