Is anyone else using MSU Denoising Filter for virtualdub? Everytime I try to use it in virtualdubmod 1.5.10 it crashes? Any ideas on what to do?
Fill in your Computer Profile, as it may have some bearing.
Try a different version of virtualdub. vdubmod isn't updated as often as virtualdub or virtualdubmpeg2. It is handy to use because of it's better audio features, but that is all I use it for now. And you can happily have multiple versions installed on the same machine, just put them in different folders.Read my blog here.
Thanks for the reply. Running good ol' Win98 at a fast paced 533mhz. Yeah, I know its way past time for an upgrade. I think I will download the other versions as you said and try running it with them. Tried it with two other versions and it seems same thing is happening. I am getting this error msg.............. An out-of-bounds memory access (access violation) occurred in module 'MSUDENOISER162'...
...while running filter "MSU Denoiser v. 1.6.2" (FilterSystem.cpp:520)...
...while running thread "Processing" (thread.cpp:120).
It seems that when I try to run another filter with MSU Denoiser thats when it crashes.
VirtualDub crashes when using MSU Subtitle Remover :(
By ralf07 in forum SubtitleReplies: 1Last Post: 17th Mar 2012, 02:16 -
Creating new MSU VirtualDub filter.
By diablo23q in forum ProgrammingReplies: 5Last Post: 15th May 2011, 15:04 -
8mm film and the msu old color restoration filter
By buckethead in forum RestorationReplies: 14Last Post: 22nd Jul 2009, 23:06 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17 -
VirtualDub MSU Subtitle Remover directions help
By LangleyM in forum SubtitleReplies: 4Last Post: 6th Feb 2008, 07:56
