  1. Help with audacity please. Basically when I try to record with my mic, it won't work. is there a special way to make sure it is using my USB device? Or is there basically any way to make it so i can record my voice with my headset.
  2. Member dwill123's Avatar
    Aug 2003
    Go into your audio control panel and make sure that "mic" isn't on mute and that the volume is up.
  3. ok thank you.
