hello
How can I extract just the audio in a mp3 or wav format from a movie xvid avi? help please
Martin
Results 1 to 9 of 9
Simple way.
Open the file on Virtualdub. Go to File -> Save WAV.
Done. -
I did open file with virtualdub but I had an error
Couldnt locate decompressor for format xvid(unknown) Virtualdub requires a video for windows (vfw) compatible codec to decompress video. Directshow codecs, such as those used by windows media player, are not suitable
Help
Martin -
Click on Tools (menu to your left), then go to the Codec section. You will find a suitable Xvid codec listed there.
Read my blog here.
thanks, I did extracted the audio file in wav format, now I can not opened it in wavelab and convert it to an mp3. How can i convert the wav file to mp3. I try to burned it with nero but it will not recognized the wav file for some reason. help
Use BeSplit or similar to remove the header since it is most likely an mp3 with a wav header.
You could also try VirtualDubMod, since 1) it doesn't require a video decoder to deal with audio and 2) it can demux audio rather than just save wav's.
You could also try VDub set to full processing to get a PCM wav.
how to convert ps3 movie to xvid/avi?
By volam1 in forum Video ConversionReplies: 2Last Post: 24th Feb 2010, 15:13 -
Extracting audio from AVI's
By KoolDrew in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 21:24 -
Extracting audio from avi - only does first 13mins
By DBIV in forum MacReplies: 5Last Post: 21st Jul 2007, 21:27 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Extracting movie audio from DVD
By CrystalDoll in forum AudioReplies: 6Last Post: 31st May 2007, 09:48
