I have captured hd-cam stuff and encoded it to divx however i have since purchased a hd-dvd player for the xbox 360. i was curious as to if there was a guide that talked about divx conversion to hd-dvd standards.
thanks
yes i did but i have the divx/avi file so i need to encoded this to hddvd compliant
Decompress it and use an encoder/authoring program that supports HD-DVD authoring.
ULead Movie Factory 6 is at the low end.
http://www.ulead.com/dmf/runme.htm -
When you encoded it to divx, did you resize it down and squeeze the living crap out of it ?
If so, don't bother trying to get it back to HD. Hardware upscaling will do a better job.
If you really want to play you might look at : http://www.thedeemon.com/VideoEnhancer/ which claims to produce high quality upscaling. Personally, I think the demo videos aren't very impressive, the performance is incredibly slow (I mean glacially), and the results, at least on moderate upsizing, isn't much better than what you can do with a good avisynth script.Read my blog here.
no i ripped it at almost full quality it like 30 mins at 2 gigs so i think its high quality
Industry-Standard For Compression / Conversion?
By zythyl in forum Newbie / General discussionsReplies: 7Last Post: 30th Aug 2009, 05:12 -
AVCHD to standard DVD conversion help/suggestions
By jstemper in forum Video ConversionReplies: 2Last Post: 12th Aug 2009, 15:02 -
Conversion of DVR-MS to Standard Mpeg2 Format
By jaffacaique in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2009, 05:40 -
Converting .VRO file onto a DVD disc (to play on standard DVD players) ?
By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 18:40 -
AVI (or any other standard movie format) to DVD conversion
By marcdcx in forum ffmpegX general discussionReplies: 3Last Post: 31st Jul 2007, 11:16
