Hey, i just completed my first dvd rip, I did JP2 with the SVCD guide at http://www.dvdripguides.com. In my 2nd and 3rd disk, about 10 minutes through, the picture gets dirtorted and the tv starts making weird beeping sounds. Anyone can help me?
#1 fastest burning speed should be 4X
#2 if you use cheap ass CD-R media, u may get blocks...try burning again with better media (certain dvd players are really picky about which type of CD-R u use)
#3 what standalone dvd player u using...make sure your dvd player can support SVCDs (and at what bitrate)...check this site to see if your dvd player can support SVCD
#4 can you watch your SVCD rip on your computer perfectly...if you get the same problems...then it could be that the vobs you ripped weren't good -
#1- I did burn at 4x
#2- I used Verbatim Media, which are preety good CD-R's
#3- APEX AV-800, does suppport SVCD's
#4- Looks good on CPU, then how can the VOB's be bad, the
DVD wasn't scratched or anything, so what would make
them "bad"
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33 -
DVD Decrypter stops after 1st cell
By MeInNYC in forum DVD RippingReplies: 2Last Post: 25th Dec 2007, 11:59 -
TV Series Rip Problems (Eureka 7 DVD)
By Migs-se in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 03:36 -
my 1st dvd recorder
By M-girl in forum DVD & Blu-ray RecordersReplies: 20Last Post: 11th May 2007, 00:15 -
1st two DVD-DL recordings failed
By DSSTBUSTER in forum DVD RippingReplies: 28Last Post: 9th May 2007, 01:23
