I convert video avi(pal) to mpeg2(ntsc) using an avisynth script and Cce sp. Ive already converted a lot of video from different resolution (480x272, 496x288, 512x408, 528x304, 512x304, 576x336, 640x512) and its working fine. The results are always 720x480 with different black border on top and bottom deppending of the resolution of the original avi.
But there is one avi left, with a resolution of 512x296 that im unabled to convert. I tried every resolution given me by fitcd but when Im importing the script in cce sp, it always say, 'frame size 748x128 is not supported. Supported frame size is up to 720x576'.
Results 1 to 9 of 9
Try:
If I used the "addborders" correctly (I don't ever use it), this should give you a 720x480 final product.Code:BILINEARRESIZE(720,416) ADDBORDERS(0,32,0,32)
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Open your .AVS file in VirtualDub. Go to FILE > FILE INFORMATION and tell us what the size really is.
Also, just try this:
BILINEARRESIZE (720,480)
This ABSOLUTELY will work. If it doesn't, then your .AVS has issues.ICBM target coordinates:
keep changing the script, until you finagle it,
BUT it's not your script !
avisynth will feed the wrong size to CCE, when there is a problem with the AVI
the first time i saw a size error, was when i tried to convert an MKV file
i've seen it numerous times since then,
I have found the best thing to do ,IF it is not an MKV, is to open avidemux and load the file, open the packed bit streams then scan and fix the frame problems, then save with a new name
sometimes i have to extract just the video file, and use fitCD to create a script for that to give to CCE
sometimes it seems the mp3 audio interferes with avisynth OR CCE and i need a video only file, even though I always have CCE set for NO audio, I encode only the video -
Read my blog here.
I tried to encode the avi without the avisynth script. So I imported the avi into ccesp and when I click encode, heres the error I get:
acmStreamOpen() failed: error 512.
The wave format is 353
So I disabled the audio into the avisynth script and encode the video with ccesp. I used RiverPast audio converter to extract the audio from the original avi.
everything ok and Im happy
Video Codec not supported
By DrAlanStatham in forum Video ConversionReplies: 3Last Post: 1st May 2012, 07:56 -
Is txt2sup still supported?
By nbi in forum SubtitleReplies: 15Last Post: 12th Mar 2012, 20:18 -
video not supported on lg tv
By zadam123 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2012, 10:50 -
Media Not Supported
By jackowens in forum DVD & Blu-ray PlayersReplies: 7Last Post: 15th May 2011, 01:01 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07
