  1. Member Yukitaken's Avatar
    Apr 2007
    Hi,
    I would like to know what is that error message refer to?
    I got that error when I was trying to burn the DVD files using TMPGenc
    Please help. Thanks.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You may need to make sure the files you are trying to burn aren't in use by any other program.
    Google is your Friend
  3. Member Yukitaken's Avatar
    Apr 2007
    I am sure none of the files were running =|
    It is always in the middle of the burning, then I got that error, I tried like 4 times. :S
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    A quick google search reveals that it is a generic error code used by multiple apps. They all basically say the same thing however, the files are locked/in use by another application (or an application is blocking access).
  5. Reboot and try again.
