I was wondering.. when creating a video for the web, in this case I'm most likely going to create a .wmv, what is the typical resolution to use? It seems when looking at a lot of video on the web that they go with a smaller size and keep the quality fairly high. Is this correct? Thanks.
Jeff
Your choices will be dictated by the site that is hosting your files. You typically create your files to meet their criteria or based on the amount of storage space available to you.
Google is your Friend
Can you recommend a good no sign up web site to send a large size video?
By coody in forum Video Streaming DownloadingReplies: 3Last Post: 6th May 2011, 01:06 -
GURU feedback needed: web server encoding and .flv size
By lucite in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 19:28 -
VideoHelp Web Site Size
By SCDVD in forum FeedbackReplies: 3Last Post: 5th Jan 2008, 04:27 -
Video for web - Quality vs. Size
By Jeff_NJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Nov 2007, 05:14 -
optimal bit rates/codec/frame size for HDV on the web
By lafsunlmtd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 15th Aug 2007, 19:09
