Hi there!
First, I would like to say that I've search the forum and couldn't find exactly what I'm looking for. So, here we go:
Final result: edit (cut-out commercials, etc.) and convert to DVD or DivX/Xvid.
Souce quality: medium or good (decent quality, nicelly preserved VHS tapes no more that 10 years old).
Available hardware: Watson 6 head stereo VCR, Panasonic 4 head mono VCR, Panasonic DMR-EH50 DVD recorder, Hauppauge WinTV-PVR-150.
Available software: all freeware, TMPGEnc DVD Author, TMPGEnd MPEG Editor, TMPGEnc AC3 Plugin, TMPGEnc Xpress and Nero.
What have I tried:
1. VCR (composite) --> Panny DVD recorder (MPEG) --> TMPGEnc MPEG Editor --> TMPGEnc DVD Author --> Nero. Result: didn't like the Panasonic recording quality.
2. VCR (composite) --> Hauppauge PVR (MPEG) --> TMPGEnc MPEG Editor --> TMPGEnc DVD Author --> Nero. Result: Hauppauge comb-filter (composite signal) messes-up the image and the bright colors are overexposed.
What I what to try:
VCR (composite) --> Panny DVD recorder (S-video, passthought, TBC?) --> Hauppauge PVR (AVI) --> some AVI capture software --> some AVI edit software --> TMPGEnc Xpress --> TMPGEnc DVD Author
My question is: is this the right setup? Do you have any advice to get better results with the same tools?
Also, another question: if I also want DivX/Xvid output, what changes do I need?
Thanks a lot in advance!
Cirruz
The first setup looks O.K. but you need a quality SVHS VCR instead of cheap or good vcr. Why because most of the better SVHS VCR has a built in stabilizer. No offense your problem is the Vhs Vcr.
Marvingj, thanks for your response! Yup, I know, my bottleneck is the VCR player... But they are expensive and I'm not allowed to spend more money with this stuff (if you know what I mean!). With "The first setup looks O.K", do you refer to the one that I've tried or the one that I'll try? Thanks again,Originally Posted by Marvingj
Cirruz
HDV .m2t footage - Best quality conversion to MPEG4- method/tools
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 01:30 -
Best method for archival
By mdod in forum EditingReplies: 15Last Post: 25th Mar 2012, 08:47 -
Is there a better method?
By quxote in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2009, 15:32 -
no burning method
By johnthescot in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 04:54 -
IVTC - Best Method?
By wrawlind in forum Video ConversionReplies: 7Last Post: 7th Aug 2007, 16:04
