This is my 1st post in this forum. Reading all the content about professional encoding etc made me feel very noobish, which I am.
I have a problem. I got the Onkyo DV-S939 dvd player from a friend. The player however would not play my dvds that I burned from .iso files with Nero. It also doesn't play any dvds with video files (divx, mpeg, avi...) on them. It says disk error.
Am I doing something wrong?
I readed some feedback about my dvd player and some people could play 'burned dvds'.
Please help me.
Results 1 to 15 of 15
A lot of the older DVD players weren't able to play DVD±R discs, how old is that Onkyo? Some of them just wouldn't play the +R discs, changing the booktype helped. With older players, your best bet is with -R discs.
According to your specs of that Onkyo model it cannot playback divx, mpeg and avi files.Originally Posted by St-Emilion
https://www.videohelp.com/dvdplayers?DVDname=Onkyo+DV-S939+&Submit=Search&Search=Search...y=Name&hits=50
Therefore it can only playback regular dvd media. You'll need to get a dvd player that is capable of playing back divx files. Do a search in google or look at the dvd players list to your left of this website. Philips and Toshiba have dvd players that can play divx.
I took the time to read the review of this player (also posted by Budz). Yikes this thing doesn't want to play anything! The last reviewer pointed out that it won't play DVD-R written by Nero, then I would suggest ImgBurn.
As Budz was saying, it won't play anything but DVD movies (MPEG2) and (S)VCD (MPEG1), no DivX, AVI, MP4... Are your ISO's from DVD movies? -
Nope, it's that simple. If you open those DVD's with Windows Explorer, do you see IFO and VOB files?
If I mount the image, yes I do see them. 2 folders AUDIO and VIDEO. In video .vob files.
Then I can think of only two possibilities, set the burn speed to 4x and/or use different brand media, preferrably media that's recommended for your burner (check the mfg website or just go for Verbatim).
So, Verbatim discs work pretty well with everything?
Also, do I have to change anythign in options? -
Of course, the best test would be to try playing your discs in an other player (not on a PC). This would prove weither your burns are OK and the Onkyo is just fussy.
Verbatim and Taiyo Yuden are Japanese manufacturers and apply higher standards in making discs. Most burner manufacturers use them as a standard to calibrate their drive's firmware.
If you mean options in ImgBurn, the default settings are all you need. Make sure it's set to DAO on the write page. -
You can use imgtool classic to create your iso image from your video_ts folder. If I'm not mistaken IMGBURN can also create a iso image from your video_ts folder.Originally Posted by St-Emilion
here's the link for the download for imgtool classic:
http://www.coujo.de/ib2/index.php?act=module&module=include&incl_name=download
It wouldn't file onto tsmuxer 1.10.6
By dude905 in forum Blu-ray RippingReplies: 9Last Post: 8th Apr 2011, 13:56 -
Why Windows 7 wouldn't let me uninstall CD/DVR drive?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2010, 22:35 -
Windows Movie Maker wouldn't capture !
By ZaYoOoD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2008, 16:19 -
Even xxx wouldn't do this... I think...
By zzyzzx in forum Off topicReplies: 11Last Post: 31st Oct 2007, 15:19 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
