For some reason, all of the programs I have tried failed. None of the others failed, I managed to change them to others using Mediacoder but for some reason this one will not convert to any other formats. The audio is completely fine though, there is nothing wrong with it I just don't understand why it won't convert?
Can someone please recommend a converter that can help me. These are the ones that I've tried already:
Audacity
Mediacoder
SUPER
Cdex
In the off chance that there is something wrong with the file, like it is screwed up or something, is there anything I can do to fix it?
You could try foobar2000. Is it a raw aac or in an mp4 container? Also speaking of itunes, it isn't DRM'ed is it?
If it is the audio extracted from your mkv, then it will be raw. You might want to try muxing to an mp4 using yamb/mp4box since aac in an mp4 container is generally better supported (not sure that itunes would handle raw aac for instance). -
switch works just fine -- i just used it on a few 1000 itunes songs
http://www.nch.com.au/switch/
and it is free - and comes with stamp , which is for auto and edit id3's"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 03:01 -
Losslessly convert AAC file to MP3?
By sldvd in forum AudioReplies: 16Last Post: 17th Nov 2010, 07:04 -
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 18:18 -
AAC to MP3
By anirban in forum AudioReplies: 1Last Post: 5th Dec 2008, 13:09 -
AAC 5.1 to WAV or MP3
By Tres_Sol in forum AudioReplies: 1Last Post: 2nd Sep 2008, 23:05
