Okay, I have an MKV and it uses an AAC Audio stream. I wanted to put this into an AVI file but I can't do it with Virtual Dub because it won't accept this kind of audio. I also cannot change the AAC into anything because for some very weird reason, it refuses to convert to any format regardless of the program I use. What I need is a program or a method of bringing the AAC audio and the video into the same file. Can someone please help me?
super, converts AAC audio,
you say you can't convert the audio
did you extract the streams from the MKV container
the IMO the MKV container is your obstacle not the AAC audio
Dl mkvtoolnix and install it, then DL and unzip mkvextractgui and place it in the folder created by mkvtoolnix
use the extrac tool get the video stream and the AAC audio stream then convert and mux as needed -
You can't put AAC into the avi container.Originally Posted by darkzero297
If you want to keep AAC and switch containers you can use the mp4 container.
You should be able to convert AAC to say mp3 with many a tool.
What have you tried?
It's only slightly more complicated if AAC is 5.1 and you want to keep 5.1 audio.
gl -
To convert aac to mp3, I use first audio2wav to convert to wav.
Then I use Adobe Audition to convert to mp3. No matter how many streams they are, Audition will split the one wav file into multiple waves. But I just "downsize" to one stream and convert to mp3. I don't bother with ac3 or other audiotype as mp3 is enough quality for me. Afterward use virtualdubmod to join video and audio.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
Converting MKV (H264/DTS) + Speedup to 25fps for PS3 Playback > Help Needed
By flexx in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 06:28 -
Help needed for converting MKV to MKV From FormatProfile5.1 to 4.1
By y0ush4 in forum Video ConversionReplies: 13Last Post: 15th Sep 2010, 04:43 -
Hardware needed to convert MKV to AVI and dvd etc quicker?
By spunge85 in forum Video ConversionReplies: 1Last Post: 16th Jan 2010, 06:40
