    Apr 2007
    London, UK.
    I have .divx files (made with Dr DivX from .VOB) that have multiple audio & subtitle streams.
    I want to simply shorten them (Dr DivX will only encode a full .VOB).
    What software can I use to accomplish this, if any?
    I really don't want to have to work on the VIDEO_TS but if this is the only way - please point me to a guide for cutting a DVD directly.
    The .divx were encoded with current DivX Pro encoder (6.5.1) under Dr DivX (2.0...).
    No menus or animations etc to worry about - just want to make a clip of a longer video.
    Thanks in advance,
    Nico M
    Apr 2004
    Miskatonic U
    simplest solution is DVD Shrink in re-author mode. Drag the title you want to keep across to the left-hand pane, select the audio and subtitles streams you want to keep, then backup the new disc to the HDD and encode from there. You can even right-click on the title and select just a segment of the video instead.
    Read my blog here.
    Apr 2007
    London, UK.
    Hi gunslinger,
    Thanks. Does DVD Shrink re-encode in re-author mode? If it can slice & dice without transcoding then this would be a solution for me? Need to preserve the original streams - do you know that it does that in re-author mode? Can't seem to find a definite statement in any of the guides .....
    It doesn't transcode if it will fit on a DVD(or whatever size you specify in the options).
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can manually set the compression to No Compression. If it is too big to fit you will get a warning, but you can proceed regardless.
    Read my blog here.
    Apr 2007
    London, UK.
    Gracias Senor! (and gunslinger).
