I have an RCA DRC8030N 'set top box' which can record to DVD discs or to an
internal HDD. I typically use it to time shift TV and record almost exclusively to
the HDD and delete the file once I've viewed it. It has very limited editing
capability and sometimes I want to split shows when I've recorded multiple
shows together or I have something that I might want to keep sans commercials
so I'm looking for a way to take one of these home recorded DVDs and edit it on
my PC for later viewing from any DVD player connected to a TV.
I normally record on DVD+RW, but I think that the unit will also record on
DVD-RW as well. I have tried to read one of these DVD+RWs on my PC, but the
disc doesn't even show up in the Windows Explorer. I am using Windows XP
Home and I'm not even sure what kind of video software came installed on my
1-1//2 year old Compaq PC.
So, can someone give me some instructions or point me to a good website or
even suggest appropriate software for the task at hand?
thanks in advance.
If you can't see any files you can't do much. Have you tried with different dvd+rw media? Does other dvd+rws work on your computer?
Some tools can edit directly from dvd recorders dvdrws like tmpgenc dvd author, most ulead video products. -
What version of Windows?
Do this:
http://digitalfaq.com/dvdguides/edit/dvdrecorder/recorderedit.htm
Edit:
http://digitalfaq.com/dvdguides/edit/editmpeg/removecommercials.htm
Author.
I use DVDWS2, SVCD2DVD, TDA and DVDSP.Want my help? Ask here! (not via PM!)
Lordsmurf, Baldrick:
Thanks for the info. I'm using Win XP Home. These sites should get me started. Some of the referenced apps are way too expensive for the ocassional use I anticipate, but there is a lot of material to wade through, so I should get some ideas.
cheers, BDT
Editing DVD Titles for display on a Sony 400disc DVD Players menu
By drewp in forum Authoring (DVD)Replies: 5Last Post: 3rd Apr 2009, 08:25 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
TMPGEnc DVD only choice for minor editing of home DVD's w/o re -encodinding
By colovaca in forum Newbie / General discussionsReplies: 4Last Post: 13th Nov 2008, 12:49 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
Editing Sections of DVD's to a new DVD without losing quality & keeping
By notpinky in forum DVD RippingReplies: 3Last Post: 18th Jul 2007, 15:51
