I have been using DVD2AVI then Tmpgenc to encode VOB files to DVD compliant files then burn using DVDit, this takes a long time, the question is - is their a mpeg2 encoder card that will except VOB files and encode them to MPEG 2 in a quicker time for around the £500 price, i,ve heared that the Pinnacle Dv500 does this but there is no mention of this on their web site.
Does anyone therefore know if this is true or the name of another encoder card that accepts VOBs or is similar to use as tmpgenc but faster.
Regards
Bri
Pinnacle DV500 has a hardware acceleration for mpeg2 encoding. It's like 2:1. The card has analog and digital inn/out. Most of the effects render realtime ( composit out only ).
The card is bundled with Pinnacle Impression CD-Pro authoring software, you can download a free upgrade to DVD-SE. -
Try Cinema Craft Encoder.......I can't tell you how to get it...but try some internet searches. That, coupled with DVD2SVCD is the fastest, most convienient way to make SVCD....
Macros -
This might be an unusual alternative suggestion, but will improve your encoding time. For the 500 pounds you were considering spending in order to eventually speed up your encoding, have you considered upgrading your computer? In fact, for that money, you could buy a whole new computer, and just dedicate for encoding. You could buy a bare-bones hot rod Athlon system for that much money, network it to your capture/rip computer, and pass the capture files to it. It wouldn't need any fancy hardware because its only for encoding.
Graham
faster blu-ray to dvd single layer conversion
By Steve(MS) in forum Blu-ray RippingReplies: 11Last Post: 10th Aug 2011, 22:02 -
Faster Resolution of Chroma Isssues During MPEG2->XviD Conversion
By onesikgypo in forum Video ConversionReplies: 5Last Post: 27th Apr 2011, 10:56 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
mpeg-4 conversion help.
By ruk_design in forum Video ConversionReplies: 2Last Post: 28th May 2007, 04:18
