Every single program I try to re-encode WMV files in (I've tried both 29.97 and 25 fps), the output files end up several seconds longer (approximately 3 for a 3 minute video) than the original file.
Why? How do I fix this? And what programs will allow me to re-encode WMV?
What format are you trying to re-enconde them into?
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
DivX-avi. Or rather, I'm trying to encode them into h.264/MP4 (ipod compatible). But in order to do it in meGUI (because meGUI is great and will allow me to customize the resolution instead of force be to use 320x240/192/176/160 or whatever), I have to encode them into a format that meGUI accepts first.
I've tried just encoding them straight off using the 3GP Ipod Converter hack (which accepts WMVs). The outputs were longer than the source.
I tried re-encoding the files into DivX-avi with Super. Same thing happened there. -
Doesn't megui support avisynth files? Then can you make an .avs file with just DirectShowSource("video.wmv") and open the .avs in megui, see https://forum.videohelp.com/viewtopic.php?t=284288
Increase framerate without making the video shorter (or longer)
By FallenAngelII in forum Video ConversionReplies: 7Last Post: 7th Jul 2010, 17:02 -
Problem with WMV files with longer audio than video
By Jumpe in forum Video ConversionReplies: 2Last Post: 26th Jun 2009, 14:00 -
Output File videwo way too fast (WMV to MP4)
By TenaciousH in forum Video ConversionReplies: 2Last Post: 14th Feb 2008, 19:53 -
ac3filter - back speakers no longer working for Prologic output
By pglenn in forum AudioReplies: 0Last Post: 7th Nov 2007, 00:09 -
cutting with mpeg video wizard but making my movie longer :S
By chocolate_brownie in forum EditingReplies: 5Last Post: 18th Aug 2007, 22:45
