Hi, i'm new. i have a problem. i bought a DR-7621N LG DVD-Recorder and when i hook it up to my TV i hear this frequency problems likes bits or bumps on the sound. I have an Antenna on the roof. the signal is perfectly fine it shows 100% signal on my TV. i hook up the antenna to the DVD Recorder and i hear this noises. i then switch it to the TV and it sounds perfectly fine. I don't know what could be causing that the DVD Recorder only make those noises when recording from the antenna or just listening from the DVD. i once did a camcorder with the outputs recording and that came out fine. so im guessing that the DVD is picking up some kind of frequency that my TV is not. and is annoying to here those bumps and bits. any help?
Results 1 to 1 of 1
problem recording game footage (from ps3) using dvd recorder
By xtube in forum DVD & Blu-ray RecordersReplies: 17Last Post: 18th Apr 2010, 15:50 -
LG DVB-T HDD/DVD Recorder Model RH2T80 - Timer Recording Problem
By KillrByte in forum DVD & Blu-ray RecordersReplies: 10Last Post: 30th Apr 2009, 22:20 -
Problem in DVD Recording in standalone DVD Recorder
By prayami in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Oct 2008, 00:35 -
replace audio with quality MP3 recording from other recorder
By daka in forum AudioReplies: 5Last Post: 26th Jun 2008, 21:08 -
Problem with recorder? Skipping only when recording on DVD
By fastheart in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 11:26
