Hi, I have a video editor program that requires "windows media encoder 7.1" I can't seem to be able to find a download for it... My question is, are there any encoders that would serve the same purpose ? I'm running win98 so that may pose a problem.. I'll keep checking for any responses, and thankyou !! -db-
https://www.videohelp.com/tools/Windows_Media_Encoder
use latest version instead"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
oh wait -- just noticed you are using win98 -- you are pouched ...
you need to run dx9 also ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks bj_m for the fast reply... I will try the latest version of wme9 , but where can I obtain the dx9 that you mention... tks.. -db-
wme9 and dx9 do not run on win98 - or even install im sure
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
Proper FLV Encoder needed - getting desperate!
By vk_dk in forum Video ConversionReplies: 3Last Post: 28th Feb 2009, 10:43 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
