hey, i have a group of avi files, what i want to do is create a still menu with each one listed, like a regular dvd, maybe a "play all" if thats possible,
then i need to be able to encode them to vob's so i can burn them
is this all possible?
thanks
Yes. And it can be done with all free tools, but there is a steep learning curve when doing it that way.
OR you can buy Sony Movie Studio + DVD (consumer version of Vegas and DVD Architect) and just let it do it for you. Other packages are acceptable, andf I'm sure they'll ALL get listed here for you sooner or later.
Regards,
NitemareEven a broken clock is right twice a day. -
Encode all the AVI to elementary MPG streams. Methods will vary depending on type and quality of AVI.
Seperate step is author to DVD. GUIforDVDAuthor will do what you want, for free. -
Shell out $40.00 & get ConvertXtoDvd....
You will never regret it.
It will convert them to dvd structure, let you make a simple menu like you want, and a few other thing's, it will even burn the finished product to a dvd if you want, i personally use ImgBurn when it's done doing it thing, but it does have the option of burning built in.
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 12:50 -
How do I create custom DVD menus?
By aple in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2011, 20:25 -
Best program to create a DVD (with menus) from MP4s?
By namrufmot in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2010, 21:18 -
How do I create a continous MPEG2 file from a DVD with video from menus
By porchmonkey in forum Authoring (DVD)Replies: 3Last Post: 5th May 2009, 05:48 -
Best program to create a DVD with menus for home movies???
By orbital517 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 21:14
