Hi there,
Just hooked up my comp to tv to watch a movie and after cloning, I can see the desktop all is ok. But when i want to watch a movie i load it up on me comp no problems, the various media players i tried can be seen on the tv, but the movie will not show on the television only comp monitor.. I get audio on the tv but were the movie should be its a dark purple screen
Any ideas as to why ? I watched a movie last sunday on my television from the comps tv out an worked fine..I havent change any settings, only screen resolution n back which didnt work..
regards,
That's a common issue likely related to your overlay settings for your video card. One easy thing to try is to set your video hardware acceleration down to about 1/3 of the slider and see if that helps. This usually reduces quality, so other settings may be better. 'Control Panel>Display>Settings>Advanced>Troubleshoot'
Usually the manual for your video card will suggest the settings needed. You can find a lot more on this subject by doing a forum search for 'overlay'.
You might also try using VLC Media Player. It has selectable overlay settings that may work. -
nVidia cards support "video mirroring". This will take whatever is playing in a media player and send it full screen to the TV output. Look for the setting in the advanced display properties dialogs.
Prob solved, rolled back to an old driver,reduced color an resolution
cheers ! -
ATI calls this "Theater Mode".Originally Posted by jagabo
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
