Is it away to Convert VOB file using virtualDubMod without loosing subtitle and audio file?
VDM will accept a VOB, but for the audio, you may need to install AC3 ACM Decompressor. I haven't tried opening any VOBs with subs with VDM, but you may need a separate program just for them.
If you are converting a DVD with VOBs to a AVI type format, it may be easier to use a program like AutoGK, FairUse Wizard, or others, that is more set up to handle subtitles.
How to convert AVI to Xvid using VirtualDubMod that plays in DVDs?
By NeroLi8gerzid in forum Video ConversionReplies: 6Last Post: 2nd Sep 2011, 14:43 -
Could someone help me through converting vob to avi using virtualdubmod
By alex.ap.pacman in forum Newbie / General discussionsReplies: 11Last Post: 14th Feb 2011, 19:38 -
Edit then convert VOB to .AVI? Best way?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 15:16 -
convert .vob to .avi
By rosmari in forum Video ConversionReplies: 3Last Post: 7th Jun 2010, 20:32 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 21:17
