How to create delayted buttons to DVD menu. For example, I want to have DVD menu about 30 seconds long, but first 10 sec to be without buttons, and after 10 sec. buttons to appear one by one.Is it possible?
Regards.
QUALITY HAS A NAME
You have to use split cell to make your button show later.
Once you split the cell you highlight second part of the cell and insert your buttons or just button highlights in second part which will be delayed.
It is a long explanation, but if you download manual and under Menu Cell you will find all info you need. -
Or you could use DVDSubEdit to make the highlights appear at a later time.
RegardsLes
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 06:03 -
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 19:06 -
DVD-Lab Studio - Selection buttons/characters
By DVWannaB in forum Authoring (DVD)Replies: 2Last Post: 30th Jan 2008, 13:49 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 07:21
