The plan was to just to cap the Sky Digital FTA Channels as i work various times of the day and this would of been handy for recording the bbc1 channel and then go back later on and watch / edit and then watch on the PC..
Good idea i thought.. Bought the dvb-s card..
Put it in, put the Sky Digi Wire into the back..
Loaded up PC and found new hardware..
And now it install the adapter (The card) So installed the software that come with that, now i need to install the BDA drivers, but i couldent as when i go to add hardware--> it picks up nothing..
So i uninstalled the adapter drivers and it picked up the BDA drivers, but now i cant install the adapter drivers, so unistalled them and installed the Adapter ones.
How do i go about this, all i wanted to do is record some FTA channels, hence not buying a CAM for it.
Spent hours on it and cant get it to work, any help would be nice.![]()
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 06:38 -
DVB-S TT-budget s2-3200
By mb508 in forum DVB / IPTVReplies: 2Last Post: 13th Jun 2008, 06:10 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 08:02 -
Which is Best DVB S PCI Card- Azurewave or Technotrend for dish ?
By sammy1 in forum DVB / IPTVReplies: 5Last Post: 11th Aug 2007, 11:27
